frozen iPhone wont let me slide to unlock
My iPhone 5 screen has been frozen for like 2 days. It won't let me slide to unlock. I tried resetting it, and it still doesn't work. Please help!
Thank you.
这是一个好问题吗?
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
Did you try a hard reset by holding the power and home button together for 7 seconds, then let go of the home button and continue holding the power button? This will restart the iPhone.
Was it dropped prior to this?
评论:
It worked! Thank you for this great tip.
由 taylorhousehold 完成的
I did that and now my screen is white
由 Tylicia Glover 完成的
thanku it did help.
由 nadeem ullah 完成的
Had my IPhone5 for 11months and suddenly froze today - could not 'slide to unlock'. However, i could 'slide to answer'.
Did a Google search on the problem and this site was the 1st that i clicked on.
So took your advice and 'Bingo' :)
Thank you so much, otherwise it was a trip down to the Apple shop.
Merv Watkins, Perth, Australia.
由 Merv Watkins 完成的
perferct, worked well ! Thanks !
由 Ste Stein 完成的
dismantle it and clean touch ic with ipa reheat with hot air station if not luck after replace logic board
评论:
Wouldn't that be super expensive?
由 You Just 完成的
Thanks so much hard close worked great - wonder why it happened
由 kpeccles 完成的
Thanks a Million it work for me and i really apprecitae it
由 Dawson Thompson 完成的
Would my phone reset
由 carly lawrence 完成的
Samsung galaxy 3 won t slide apps
由 aj Meek 完成的
If you dropped your phone or if you or someone else replaced the screen or something dealing with opening the phone, then the screen might be messed up (LCD & touch screen). Replacing the screen should be a final solution after trying the other solutions mentioned above by others.
评论:
So what you can do to use your phone is connect the earphones, and you can at least answer calls... you can either mute your phone or leave it as it is, then you answer & end calls you push the middle button from the earphones and decline with the plus or minus. Hope this helps...
由 Jacob 完成的
I was in voice activation. the it took me to the ist page, was giving me a comand that . It will not even let me turn off the phone. nowsaid slice to unlock, i did it but nothing happened.now i got amessage that the phone is disable. What can i do?
由 Vivian Julia 完成的
OMG it works for everything thank god
由 Jacob Stone 完成的
What you have to do is hold the sleep and home button for ten seconds and let go of the Home button but still keep holding the sleep button and your Phone should restart and when it does it goes a bit Black but just wait and it will be back to normal
Just do a hard reset HOLD THE OFF BUTTON AND HOME BUTTON FOR SEVEN TO TEN SECONDS AND THE SCREEN WILL GO BLACK AND THEN SHOULD TURN BACK ON and there you go!
评论:
Try'd hard reset but my phone is still frozen. Now its turning off and on. Any other ways to fix it.
由 Joel Lawson 完成的
This did not work for my phone and I have tried it 2x....
由 Gwynne 完成的
tried all of the above not working...
由 Gwynne 完成的
this dont work i have a notification froze on my screen too it will lock and unlock but hard reset WILL NOT WORK what else can i do and its not the touch sensors this phone is a iphone 7+ brandnew was working fine
由 Michael Ivie 完成的
But what if the home button isn't working? Then how you do it?
由 Christina 完成的
过去的24小时: 3
过去的7天: 18
过去的30天: 120
总计 396,104
i ve tried the hard rest option bt its not working n d screen has ben locked since almost 48 hours n unable to unlock it in any manner
由 darestare3 完成的
What did you do to fix it?
由 Oplkjhgfd 完成的
Great thanks problem solved with hard reset
由 peteralindsay 完成的
worked for me - thanks everyone!
由 cindyoffenbacker 完成的
Hard reset worked ... wonder what casues this and how to avoid it
由 Viren Doshi 完成的
显示更多的50条评论
