跳转到主内容
加入维修社区 - 创建账户
Model M7572 / 400 or 500 MHz G3 processor
Motherboard replacement.
Is it possible to get to the motherboard to remove and replace, from the rear of the powerbook? All the instructions I see are ones that you have to Start at the top. That seems like a lot of work just to replace that board.........? Thanks, Bob
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
最有帮助的答案
Unfortunately, it's not possible.
Apple goes back and forth with machines on making the upper case or the lower case the "base" of the machine. WIth the Pismo, everything is screwed into the lower case. It is impossible to remove all these connections from the bottom, as all the screws are accessed from the top.
Sorry!
这个答案有帮助吗?
得分 1
添加一条评论
From the top's the only way to go I'm afraid! It shouldn't be too hard, just follow the guide. (Watch out for step 41!)
这个答案有帮助吗?
得分 0
添加一条评论
Thanks to all that posted here re: getting to the Logic board from the rear, rather than from the top. I have the take apart manual, but will have a techie do it for me. Thanks again, Bob
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
bobpal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 2,187
