跳转到主内容
加入维修社区 - 创建账户
初代iPhone(又称iPhone 2G)。型号为 A1203,存储容量有4GB、8GB、16GB可选,机身颜色仅有黑色搭配金属铝。维修初代iPhone是容易的,需要耐心,一些工具和焊接技术。
Camera shutter doesn't open!
I have been having problems with the camera lately, with the image on the screen being bright red and blue. Now the camera shutter does not open when activating either camera app. Anybody have an idea?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
Strange....
The first place to start would be a software restore (be sure to back up your data first).
After that, I would say try replacing the camera.
If this does not solve the problem, all signs point to logic board.
Good luck!
这个答案有帮助吗?
得分 2
4条评论:
Yeah, sounds like a software problem. These phones don't have a physical shutter.
完成的
2 iphones with broken cameras following water damage both displayed only the closed shutter. no prob with software in these instances.
完成的
good answer +
完成的
I'm assuming that the software opens the "shutter" when it successfully activates the camera. If the camera won't initialize, then the shutter doesn't open. I'd say the camera is the most likely culprit, not the software. Good call.
完成的
添加一条评论
my camera say cant open
这个答案有帮助吗?
得分 0
添加一条评论
I once had the problem. Power Cycled, rebooted, no help.
libmobiledevice restore helped me.
Then replace camera if lmd does not help
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
HUTCH000 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 3,253
