跳转到主内容
The fourth iteration of the popular 7" Galaxy Tab line of Samsung tablets.
132 个问题 查看全部
My tab WONT TURN ON need help
so i was using my LTE samsung galaxy tab 4 7.0 this after noon its like brand new I've had it since october mid way trough so its less than two months and i pressed the button for the screen to go dark not off just to sleep and feel asleep i woke up about an hour later and it wouldnt turn on it was at 50% so it was fine for the rest of the day and i only had 2 applications running which is not a lot compared to what i normal have, like they weren't open they were just there in the back round and now it wont turn on and I'm using it as my phone so i don't have a phone now ether i don't know what to do I've tried pressing all the buttons and holding them down i plugged it in to the charger and it didn't even show that it was plugged in its not over heated and when i plug it in it doesn't over heat what should i do if it doesn't work in the next couple of days it will go back to the store where i brought it from but its in singapore so I'm trying every thing i can to fix it here so it doesn't have to make that trip :/
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 7
2条评论
Mine is the same way but no water damage or never been dropped
完成的
Read this article to get rad of your problem https://www.getthetechnow.com/2020/05/ho...
完成的
添加一条评论
1个答案
已选择的解决方案
Have you tried a hard reset ?
http://www.technipages.com/galaxy-tab-4-...
May help, good luck
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
jasmin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 2,538
