跳转到主内容
加入维修社区 - 创建账户
2014 年 1 月发布,搭载 Android OS V 4.2 (Jelly Bean) 操作系统,配备摄像头、MP3 功能、双卡双待和 WiFi 功能。型号为 D572a。
Why does my phone not turn on?
I can't get my phone to turn on. It just appears as a black screen.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 20
2条评论
my screen is white with BLU ON IT and its been like that for hours.
完成的
My screen is black with BLU on its been like that for hours
完成的
添加一条评论
9个答案
最有帮助的答案
There could be a couple of reasons for the phone not to turn on. Try turning your phone on, by pressing the power button for 7 seconds. If this does not work try to charge your phone. Connect to a charger and let it charge for a 30 minutes and then try to turn it on. As simple as it may see check that the charger is plugged to the wall. If all these don't seem to work, it could be possible that the battery is drained. Try to replace the battery. See Replace Battery Guide
这个答案有帮助吗?
得分 4
添加一条评论
Why isn't my blu 5.0 not charging nor turning on
这个答案有帮助吗?
得分 2
添加一条评论
my answer is more of a question what if the power button is messed up
这个答案有帮助吗?
得分 0
1条评论:
why dose my phone turn on and off every minutes
完成的
添加一条评论
My phone don't turn on it got steam in it what do I do
这个答案有帮助吗?
得分 0
添加一条评论
this BLU phone is sucked i just got my phone not even a month but its not working anymore
这个答案有帮助吗?
得分 0
添加一条评论
My blue 5.0not taking any charge nor turning on what's the problem only have a red light but not charging nor turning on
这个答案有帮助吗?
得分 0
添加一条评论
Mine cannot charge I charged it for 9 hours and nothing
这个答案有帮助吗?
得分 0
1条评论:
I charged mine for 9 hers -_- NOTHING
完成的
添加一条评论
same problem. just take out the battery and let it cool down and then put it back
这个答案有帮助吗?
得分 0
1条评论:
Any help pls?, Blu STUDIO 8.0 with in built battery not charging or phone turning.
完成的
添加一条评论
The way i fox it was when the keys are turned on but the scrern isnt showing then you hold the power button down and if the keys are on let if go off then hold the power buttons until it turns on
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cristal Cardiel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 8,933
