跳转到主内容
Mac mini 是最初发布于2005年1月22日的小型桌面电脑。目前,它是 Mac 桌面电脑产品线四款产品之一,主要作为一体台式机 iMac 的替代产品。
What is sensor on harddisk? How to re-attach?
When I took out the harddisk (without removing the logic board) I had some struggle until it came out.
When it came along, a cable with some tiny logic board fell down. It looks like some kind of sensor (maybe temperature?) and it looks like it was glued to the harddisk.
Can you confirm that this is a temperature sensor?
How to re-attach it? Just some standard glue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
5个答案
最有帮助的答案
This is the temperature sensor, and you should reattach it with glue that is conductive (in terms of heat) or electrical tape (you want it to be as close to the HDD as possible as to get the most accurate temp readings.
这个答案有帮助吗?
得分 1
1条评论:
What type of glue is that? Any idea where to get such a glue? I used ordinary glue and hope that is good enough.
完成的
添加一条评论
Question is: Is temparature sensor show stopper for Hard Drive replacement or not?
这个答案有帮助吗?
得分 0
1条评论:
I agree, I mean theres only one fan there. But if your HDD ever goes above 50C you'll never know... (Unless you check the SMART status)
完成的
添加一条评论
I think i found my answer and placed an order from amazon. Looks like sensors can be used with aftermarket HDDs
Check this.
Will try with my 750gb WD which currently sits in my 2009 mini ;)
这个答案有帮助吗?
得分 0
添加一条评论
I scraped the glue off of the old drive and stuck it on the new. It was very pliable, sorta like rubber cement.
There is also one on the SATA connector, but since that stays, it should not be removed.
Make sure you check the thickness on your replacement drive, it is a very tight fit and I don't think any of the thicker high capacity drives will fit.
这个答案有帮助吗?
得分 0
添加一条评论
I just pulled sensor off slowly and glue came with it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
http 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 4,346
