跳转到主内容
What is wrong with my iMac?
I have a iMac g5 that had a broken logic board and power supply. I replaced the logic board and power supply and now the iMac will start up. But the problem is something is wrong with the operating system. It will just load when turned on and the fans will get fast and then shut down. The hardware is fine. But I tried putting in the install disks and holding command c but while booting the screen will be white for 10 seconds and then continues to load again and do nothing. What do I do to fix it? I heard I might need to replace the hard drive and do a install but I don't know. Does anyone have any ideas what to do to fix it. - thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
If you have the grey recovery Cd/DVD that came with the system you should be able to get the system to boot up with it in the optical drive within the system.
If you can't get your system to boot up with the optical drive you may still have a logic board issue or the optical drive needs cleaning.
If you still can't get the system going you'll need to open the system again and check your connections.
这个答案有帮助吗?
得分 3
4条评论:
Thanks man for commenting but I already tryed the DVD install. It ejected it. I'm going to replace hard drive because I wanna 1 tv and do a install on that one. But you might be right on cleaning the disk drive do you have any idea how I do that?
完成的
Hold on here! If the disk was rejected are you sure you re-started the system correctly? Review this Apple TN: Startup key combinations for Intel-based Macs
完成的
I would hold off on altering things until you can get the recovery Cd/DVD to load up. Then you can check things out before spending any money.
完成的
You'll need to pickup a CD/DVD head cleaning disk which has a very small brush to clean off the lasers lens. Also you could try a small blast of can'ed air make sure none of the liquid exits as that will fog the lens.
完成的
添加一条评论
添加你的答案
kyle campbell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 444
