跳转到主内容
Staples light-duty electric pencil sharpener, model no. 34462.
Why isn't the pencil sharpener properly sharpening my pencil?
When I use the sharpener, the pencil's point comes out badly off-centered. Or the sharpener is only roughly sharpening my pencil when I try using it. Or my pencil lead keeps breaking instead of sharpening.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
3个答案
已选择的解决方案
This is probably due to a dull or worn cutter or a foreign object being jammed in the pencil bore. To fix this problem, you’ll need to replace the worn or dull cutter blade or unplug the sharpener and try using a narrow tool (e.g. a paperclip) to clear the pencil bore.
这个答案有帮助吗?
得分 4
1条评论:
YES thank u I used a paper clip (once unplugged) and I got out a couple of tips that had broken. Thank u! Works like new again ?
完成的
添加一条评论
I purchased a brand new wall mount X-ACTO KS pencil sharpener. I had the same problem beginning with the very first pencil i tried to sharpen. I find that, today, manufacturers are more concerned with sales rather than quality control. After all, when your sharpener fails to operate properly, you’ll just buy another. You might consider a vintage sharpener on eBay, because those were a quality product for sure,
这个答案有帮助吗?
得分 2
添加一条评论
i noticed this with older sharpeners when the blade gets dull try looking for a replacement cutter if the manufacturer or model supports it, if not replace the whole sharpener with a newer or better model/version, OR you can try to sharpen the blade carefully if it is a vintage sharpener
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Brian Eliason 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 79
总计 18,596
