跳转到主内容
The HP Compaq nc6400 is a thin and lightweight 14.1” laptop in HP’s business line. The device was released in May 2006.
Window Vista installation error message
This is the error message that l get when l try to instal window
Non-system disk or disk error
Replace and strike any key when ready
Please what can l do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
in which part of installation you have this error ?
完成的
Just. Turned on computer and this message was on here
完成的
添加一条评论
1个答案
Ok bud. So this is when the bios can not find the operating system. This could be an easy fix! Go into your bios settings, which should pop on when turning on the computer. Maybe F9? F12? One of those. Go into your Boot settings, look it up if needed. And change the hdd that starts on boot.<—- Look that up if you need to know how. “Change hdd that starts on boot” or along the lines. It may not have one OR you have two hdd’s in there and it doesn’t know which one to boot off, so you just switch it.
If that doesn’t work, you may need to reinstall Windows XP. But before that, try what I said.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Franklin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 203
