跳转到主内容
宏碁在1997年购买了德州仪器的移动PC部门,从此进入了笔记本电脑的世界。
1684 个问题 查看全部
Can the RAM be upgraded on a Acer Chromebook 13?
Can the RAM on the Acer Chromebook CB5-311-T9Y2 Tegra K1 be upgraded on the 2GB model to 4GB (or more)?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
From what I can find online it appears the system has soldered on RAM so its not upgradable.
You may want to give Acer tech support a call to double check.
这个答案有帮助吗?
得分 4
1条评论:
From the acer forum they also say that the RAM is soldered:
https://community.acer.com/en/discussion...
完成的
添加一条评论
No, it can't be upgraded. But you can get a bit more performance using some virtual ram from the SSD.
Use "crosh" (Ctrl-Alt-T) and enable swap ram:
crosh> swap enable 2000 (this will allocate 2GB extra memory)
crosh> swap status (will give you status of VM usage)
这个答案有帮助吗?
得分 4
2条评论:
Wow, I didn't know this was possible and really hope it helps when my machine becomes sluggish in future. Thanks
完成的
Is this only possible on a chromebook?
完成的
添加一条评论
Did the crosh fix.. actually helped me out with my new Chromebook 13, have 4gb ram with 32 gb ssd runs quite well. Love tying on it far better then the 11.6. my stubby fingers play !&&* with the smaller keyboards. Though must admitt I found the Acer C820 to be quite easier then previous models .Plus the i3 with 4 gb ram was really good. Could upload a video file in 720p to youtube that was placed on it very easy and almost as fast as my regular i5 asus laptop.
Waiting to see how the chromebook does. Looking forward to seeing if Google adds more apps, though honestly since my first chromebook had pitful selection. Now it's far better. From what I hear the newest Mac is lackluster.. esp. for the cost. Got my chromebook on ebay new for under $250.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mace Moneta 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 21
总计 6,965
