跳转到主内容
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Display hinge is broken. Is a replacement possible?
I used to have the bad habit of carrying my MacBook Pro around by the right edge of the display. As a result the right side of the display can now be moved up and down a fraction of an inch and the hinge is getting looser and looser by the week.
Does this sound like a problem that would be fixed with a new display or does it seem like the problem is with the body?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Getting to the hinges on the body side is not to difficult. Follow this IFIXIT guide: MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement. Stop at Step 10 which will have exposed both hinge sides. Get some fingernail polish to dab a small amount just under the screw head to help prevent it from loosing up and tighten the screws as needed making sure your lid is square.
这个答案有帮助吗?
得分 1
1条评论:
If this answer answered your question please remember to rate (score) and mark it accepted.
完成的
添加一条评论
添加你的答案
jbfx 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 244
