跳转到主内容
Repair and disassembly guides for Lexmark printers.
19 个问题 查看全部
Lexmark Genesis s816 has slowed to a crawl
After several years of very successful use, my multifunctional device slowed to a snails pace when printing anything. It takes over 4 minutes, for example, to print a test page. What could be the problem?
The device is running the latest firmware.
Thanks, Anna
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
HOW TO FIX LEXMARK GENESIS SLOW PRINT
I have also had a lot of problems with slow printing of and on. Never had time to look into the problem until now.
- First try closing network/wifi connection via the display on the printer.
- Power off the printer.
- Close any wifi or other network connections you have been using for the printer. Like a router, mobile device etc.
- Use the USB cable ONLY for printer connection.
Now power the printer on again.
- Make sure the wifi-icon on the display HAS the yellow triangle warning. If not start over again from top.
- Test printing again.
If the problem persists update drivers etc.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
belkjab 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 13
过去 30 天: 14
总计 188
