跳转到主内容
An Android prepaid smartphone released in 2013 by Virgin Mobile.
18 个问题 查看全部
Why does my ZTE Awe Has Shortened Standby Time?
My Phone's battery life drains so quickly, even when I'm not using it. My phone will be apparently inactive for hours, but when I check the battery life, the percentage shows a decrease in battery life.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
Be aware of excessive applications running in the background as well as screen brightness. If these simple fixes don't improve the battery life, the battery could be damaged which in case you would contact the manufacturer.
这个答案有帮助吗?
得分 0
添加一条评论
My phone has the same issue, apparently this model is battery hungry. I manage it by leaving the Bluetooth and wifi turned off, unless it's on a charge cable, or I use the functions for a minimum period.
Try eliminating all but those apps that you use often, also have a large capacity mini SD card inserted, move all apps that you use to it, and perhaps get a backup battery booster.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joseph 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 115
