跳转到主内容
Released September 2013, the Visual Land Prestige Pro 7D model number ME-7D-8GB is an affordable and sturdy tablet designed for kids.
26 个问题 查看全部
Why won't my device charge?
I tried charging my device using the supplied cable which is in good condition and it didn't work.
The device is out of power and I can't get it to turn on. Up until now my device would charge but would lose its charge faster and faster.
It showed a low battery icon the first few times I tried to turn it on after it ran out of battery, but now it doesn't do anything.
What should I do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
how can you tell when the battery is fully charged.does the battery icon ever supposed to turn green mines stay yellow.
完成的
Had the same problem with my tablet charge it and boost and it still wouldn't come on . Got a new charger and the same thing what is wrong with this tablet only had it six months.
完成的
添加一条评论
2个答案
已选择的解决方案
Your battery may need to be replaced. Follow the Battery Replacement Guide for instructions. The guide can be found here.
这个答案有帮助吗?
得分 1
添加一条评论
Trash it. Cheap tablet. They supply defective xformers which overheat, short out and blow the Charging circuit inside the tablet. Mine lasted less than two weeks.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Max Hudson 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 6
总计 2,700
