跳转到主内容
加入维修社区 - 创建账户
Nokia Lumia 920由诺基亚开发并于2012年11月发布,搭载Windows Phone 8操作系统。
Why is my battery draining so quickly?
Even after having 100% charge, my phone dies in about 4-5 hours. My old phone would last a full day before needing a new charge. Please advise.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
A couple of reasons might be why the phone is drained of battery quickly.
The main reason why is usually due to high consumption of battery power from apps with large processing power. In that case either delete apps that are normally not used or turn off apps such as GPS, Bluetooth, any cloud service as well as screen brightness.
You might also want to try using Power Save Mode to increase battery life. Power Save Mode should be located either in Settings, or even on the main screen.
Resetting your phone might help solve your problem using either a soft reset (pressing and holding the Power and Volume Down keys simultaneously for 15 seconds) or a hard reset, located on Settings (which will return your phone to factory default).
Another reason might be the charger and where the phone is being charged. Keep in mind that using your computer to charge your phone takes longer than a regular wall plug.
And last but not least, it may be the battery itself, in which case you may need to replace it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Zadan Ly 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 20
总计 2,496
