Replace Airport Extreme board in A1150 with board from A1211
The Airport Extreme logic board of my A1150 non-unibody MacBook Pro is broken. Now I got an A1211 for spare parts. The Airport Extremes look different (compare iFixit Manuals: A1211 (https://d3nevzfk7ii3be.cloudfront.net/ig...) and A1150 (https://d3nevzfk7ii3be.cloudfront.net/ig...) – consider the number of antenna cables in particular).
Should or might it work as a replacement? Which two cables should I connect then?
(And, additionally, in someone can answer by any case: Can I replace the left fan in the same regard?)
guess I found the solution iFixit's store section (MacBook Core 2 Duo 802.11n Airport Extreme Card) seems to be imcompatible.
由 Tom 完成的
