跳转到主内容
Repair and disassembly information for Logitech's H800 wireless headset. Supports 2.4GHz & Bluetooth. Released in 2011. Model number: 981-000337.
19 个问题 查看全部
How about the low-battery annoying beeping?
Hello,
I own the same device, and I am looking for a solution to the 3 seconds beeping that happens for hours before the battery runs low and just don't let me make the best out of the headsets. Is it possible to identify and cut the line that is responsible for that sound permanently? I would know if the battery is low when sound no longer comes out, as easy as that.
The engineer behind this idea is plain stupid, you don't tell people that the highway is no longer usable at a certain distance by placing nails on the road every meter.
Could you please kindly and generously guide me with your high wisdom through this deed?
Thank you,
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 11
6条评论
Annoying doesn't begin to describe it.
完成的
Ohh My God logitech - please fire whoever is in charge of this beeping!!!!! YOu suck!!!!!!!!!!
完成的
I got tws-i8x Bluetooth earbuds. When battery reach 30% the sound of beep and Please recharge keep popping up every 10 second.
There is anyway I can disable the earbuds beep and the sound notification at least to 10 or 5% which more convenience?
完成的
Please take the beeping off can't enjoy headphones make you want to trash them or send them back
完成的
I'm in the same situation as you guys look I think what they did is dumb because my headphones last a whopping 24 hours but start beeping at 30% non stop every 2 mins its dumb because I know for a FACT that there is 7 hours and 20 mins remaining I DID THE MATH so really I have to charge it after only 17 hours instead because of this annoying choice of when it beeps like for the love of god JUST MAKE IT 5% EVERYONE WOULD ENJOY IT MUCH MORE sorry for rant but yea same problem I need someone to help fix :/
完成的
显示更多的1条评论
添加一条评论
3个答案
已选择的解决方案
Mine does the same thing. What I am going to do is buy a super high powered cell phone battery
and replace the inner battery with it. I did the same thing to a pair of H600's . Put 3 AA Battery holders
on the headset around the top and removed the little 'chicklet', battery that was inside.
They now run for about 96 hours instead of the normal 5 hours..
这个答案有帮助吗?
得分 5
3条评论:
Would you do a video of this or a guide?
完成的
Does it still charge via the USB or externally ?
完成的
Plz do a video
完成的
添加一条评论
In Ubuntu, you can go to sound/sound effects
and mute alert volume:
这个答案有帮助吗?
得分 2
3条评论:
Does this help ? From what I understand the beep is generated BY THE HEADSET ?
完成的
Back then it seemed to solve the problem, but now it doesn't stop the beeping :(
完成的
2020 and I stilll hve the same problem :(
完成的
添加一条评论
Just send them back no point owning them for half the charge its guarnteeing
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Houssam 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 26
过去 30 天: 102
总计 76,388
