跳转到主内容
Updated version of the Kindle Fire 7" tablet by Amazon with 1280x800 HD display. Released September 2012. Repairing this device is straightforward.
Keyboard won't pop up
I only had my Kindle Fire HD for a matter of months before the keyboard stopped popping up. I click into a Search Bar (or something else that requires me to type) and... nothing. This obviously limits its function, so now it's pretty much just a dust collector. Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 30
18条评论
I was on my KF HD and when I went to aptoide my to update my Kik and my keyboard and my shyt stop popping up someone plzzz help me before I end up breaking my god dam kF
完成的
that happend to me too
完成的
This sucks someone help
完成的
Brandon, Same exact thing happened to me
完成的
It happened me too I have to use a japeniese keyboard ITS SOO FRICKIN ANNOYIN HELP ME PLEASE SOMEONE HELP I BEG U
完成的
显示更多的13条评论
添加一条评论
17个答案
最有帮助的答案
I found a solution guys you go to SETTINGS then KEYBOARD AND LANGUAGE the scroll down to CURRENT KEYBOARD and select JAPANESE keyboard that will make the key board pop up but itll write it in japanese but where the "SYM" symbol would normaly be there you can change to engle there will be a japanese symble and A and a 1 put it on the A and go to store then you can type and add a keyboard from there typing problen solved
这个答案有帮助吗?
得分 12
11条评论:
Thank you so much for the posting, it worked....!!!! problem solved
完成的
This worked amazingly well. Thank you so much. The Japanese keyboard has an English option like Jose said. You just tap on the letter A down in the bottom left of the Japanese keyboard. This lets you type in English. Then go to wherever you download apps and download a new keyboard. This allows you to be able to type,"keyboard," in the search.......The only problem I had afterward was after the program downloaded you have to be able to go back in your settings to the keyboard setting and it was in Japanese So note what that looks like. Then you scroll down the list there of possible keyboards and the one you downloaded will be in there. My new keyboard was on the same screen that the settings was on, so it was easy to find. Anyway you shut off the other buttons in the keyboards and enable the new one you downloaded. This is working great now and the new keyboard is much better than the one I had.
完成的
when I select CURRENT KEYBOARD SETTINGS it kicks me back to the main settings screen :(
完成的
wish I had googled this before I bought a new Fire! Jose it worked and I can at least now open things which had parental control. Thanks :)
完成的
I cant go to settings without my password.... and I can't type in my password without my keyboard... T-T
完成的
显示更多的6条评论
添加一条评论
Hi. Have you tried resetting the unit?
Resetting your Kindle Fire can solve intermittent problems. To reset your device:
Make sure your device is disconnected from any power source.
Press in the power switch and hold it there for 20 seconds.
The screen should turn off, once the screen is fully turned off press the power button in for 2 seconds and release. The device will turn back on and you will see the Kindle Fire loading screen.
This reset will not affect any books or content you have on the Kindle.
这个答案有帮助吗?
得分 5
5条评论:
Will not work if the keyboard was removed all together. I'm not sure why the keyboard function is gone but still have the ability to log into the password screen to access the kindle HDX 3rd gen but it still works. if you guys need a solution an you already have aptoide on your kindle just search through the available apps shown for Flash Keyboard (no you dont have to type anything) download it (might take awhile ) install it and you're good to go if this doesnt work post and i'll try to give you another alternative.
完成的
Doesn't work im sry but plz if u can help plzzzzzzzzz
完成的
Can't reset when parantal control are on as need keyboard for password
完成的
I cant reset without typing my password in... I need my keyboard for that.... T-T
完成的
just factory reset it
完成的
添加一条评论
Install a new keyboard and then set that as ur default
这个答案有帮助吗?
得分 4
14条评论:
My kindle fire hd 7's keyboard won't pop up at all so now i can't even log into it. PLz help
完成的
Cant install anything Keyboard will not pop up
完成的
Ya know, I could do that but there is just one problemo...THE KEYBOARD WONT COME UP TO TYPE THAT
完成的
Swipe down from the top of the screen and tap Settings. Tap Device Options, and then tap Reset to Factory Defaults. Tap Reset to confirm.
完成的
I'm trying to reset it, but I have parent controls and it won't let me reset because I have to put in the parental controls password
完成的
显示更多的9条评论
添加一条评论
I tried many solutions, the only thing that helped my kindle was setting it to factory default (Settings > Device > Reset to Factory Defaults ).
But you will loose all installed applications, pictures and other stuff.
这个答案有帮助吗?
得分 1
添加一条评论
If you dig through responses, a user named Far Isle explained a PERFECT solution….as long as you can access the main screen. Go to Settings, Device Settings & Keyboard option. From that screen, deselect the US English Keyboard and select another country’s English keyboard! I selected both Canada and UK…defaulted to UK on my Kindle Fire HD 10. For good measure I held down the power button until it shut off and then waited a minute before restarting…now the keyboard comes up and types beautifully! (As it should!!)
这个答案有帮助吗?
得分 1
添加一条评论
P.S. I typed this six weeks ago and no issues since!
这个答案有帮助吗?
得分 1
添加一条评论
I have the same issue. but use the voice button, or Alexa to get somethings done. I can't find the setting for the keyboard.
这个答案有帮助吗?
得分 1
添加一条评论
Change your keyboard's language to a different language
这个答案有帮助吗?
得分 0
3条评论:
This was the best suggestion. Changed keyboard from English US to English Canada, then rebooted Kindle Fire HD and keyboard reappeared!
完成的
Worked! Thank you.
完成的
I did thank you!
完成的
添加一条评论
That worked! Thanks.
这个答案有帮助吗?
得分 0
添加一条评论
my amazon tablet keyboard will not pop up what do I do
这个答案有帮助吗?
得分 0
1条评论:
how do I fix my amazon fire tablet if my keyboard will not pop up
完成的
添加一条评论
It is just when I click the search bar on any app the keyboard will just keep on glitching and I realy need it fixed
这个答案有帮助吗?
得分 0
添加一条评论
My keyboard kinda does this too but when I play a game called rolox the keyboard doesn't pop up it Only pops up when my battery is low :(
这个答案有帮助吗?
得分 0
1条评论:
Do you mean Roblox?
完成的
添加一条评论
Try going to keybord settings and making your keyboard another colther it kinda works
这个答案有帮助吗?
得分 0
2条评论:
cant get to settings
完成的
half screen only
完成的
添加一条评论
me to; when I had a software update BOOM for some random reason my key bord stopped popping us amazon plz fix this
这个答案有帮助吗?
得分 0
添加一条评论
I had this issue for my Fire Tablet 10HD (9th edition). Adding a new keyboard worked. I was also able to make it work with the Spanish (Latin American) keyboard so maybe any other keyboard works. With that new keyboard added I was able to factory reses the device (mine needed a PIN to reset it) and the keyboard works great in my original non-functioning language (English) after the factory reset.
这个答案有帮助吗?
得分 0
添加一条评论
Hold the power key down for 40 seconds and let it reset itself. When you switch back on, the bug should have gone. At least this worked with mine.
这个答案有帮助吗?
得分 0
添加一条评论
So check the new comment the person put before you it will help you and your problem -Hope it helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Stephanie Roberson 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 30
过去 30 天: 169
总计 76,284
