跳转到主内容
Released in 2004 and identified by model number J3680. Compatible with Windows 2000 and newer software, and with OSX 10.3.8 and above.
7 个问题 查看全部
How can I get my scanner to print a PDF?
The only files that are available are BMP, JPG, PNG and TIFF. Am I able to print a PDF? If so, does anyone know how I can do that.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
See if this answers your problem: Officejet J3680 scan to PDF option missing
这个答案有帮助吗?
得分 1
添加一条评论
The most common cause of this issue is you may have the basic driver installed (which does not support PDF scanning), rather than the full feature software and driver installed. To install the full feature software and driver, go to the hp website:
http://h10025.www1.hp.com/ewfrf/wc/softw...
Then, select your operating system (windows xp, windows 7, windows 8, etc), click next, scroll down until you see "drivers", then select "download."
I hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Marisa 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 198
