跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
Screen not responding properly to touch
My screen was not responding to touch as it should (i.e. either no reaction at all in certain spots and otherwise jumping around when touched).
I replaced the screen as advised and at first it was much better as only one small spot on the screen was unresponsive and there was no jumping around. However, after 1-2 weeks it is now worse than it originally was. When the screen is touched it jumps almost every time (i.e. if I click on a message it acts as if I swiped it to delete or if I touch an email it won't open and the screen will jump up and down).
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Make sure when you replace the screen that no dust or debri gets in the enclosure and that it is sealed properly...also the ribbons connecting the lcd to board may also be faulty. you can try reseating the screen again and then test or if you are still under the warranty for the part used you can see about getting it exchanged.
这个答案有帮助吗?
得分 1
1条评论:
Unfortunately, the phone is not under warranty. If it is the lcd ribbon is there anything I could do?
完成的
添加一条评论
All the signs of a faulty screen and its deteriorating through time..
Time for another screen remember cheap is not always better
这个答案有帮助吗?
得分 0
1条评论:
Thanks though I'm not sure if it would be related to actual screen as I've had this problem within two weeks of installing two separate new screens. Also the screens I buy aren't cheap, they are sold by iCracked on Amazon are are generally rated high. I have bought from them for other phones and never had an issue before.
What do you think?
完成的
添加一条评论
添加你的答案
Yonah Stern 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 5,736
