跳转到主内容
加入维修社区 - 创建账户
The HTC One X is the first HTC phone to be equipped with a quad-core processor, released in April 2012.
Solution for distorted audio?
I've never had a problem with my phone's audio until recently where it's become distorted and quiet, what could have caused this problem and is there anything I can do to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
There are a few things that can cause your audio to stop working properly, and each requires a different fix. The first thing you should do is make sure that the holes over the speakers aren't just clogged. Look on the back of your phone, and see if there's dirt in the small line of holes near the bottom. If there is, running a fine needle through them should solve the problem. If that doesn't help, try making sure your software is up to date, because this might also be causing performance issues. If there still isn't any improvement, your speakers have probably blown out. You'll have to replace them.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nyles Peterson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 132
