No start no crank
My 2000 GMC Yukon will click but no start and no crank. Replaced the neutral safety switch and didn't fix. Seems to happen most when sitting, wet or cold. When I take it to the shop it does not duplicate.
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 4
总计 444
If it is clicking when you try to start it then it is most likely a bad connection at your battery or starter. Make sure both are good. Clean terminals at battery with wire brush and liquid battery cleaner even if they look good. Check all your grounds and make sure they are corrosion free. Clean them and re-install regardless. Let us know what you find. If you have not done so already check your starter with a voltage meter when it is doing it. See if you are getting 12 volts to the solenoid. If not replace the starter.
由 JackoAllMasteroNone 完成的
