跳转到主内容
The Samsung Gear Live is an Android Wear-based smartwatch announced and released by Samsung and Google on June 25, 2014
10 个问题 查看全部
The charging cradle broke. Can I replace it?
The charging cradle on my Samsung Gear Live broke. Are replacements available or can it be repaired?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
A chips bag clip works just dandy.
完成的
يرجى توضيح أكثر هذا قليلا
完成的
添加一条评论
5个答案
最有帮助的答案
Had issues with mine, little plastic snap opposite of button side of device.
这个答案有帮助吗?
得分 2
添加一条评论
In the event of your Gear Live's charging cradle breaking, replacement is your only option. Unfortunately, the charging cradle's design does not facilitate repair, so that option is unavailable.
这个答案有帮助吗?
得分 0
添加一条评论
It's worth noting that at this exact moment there appears to be no way to replace it. Samsung will just refer you to Google, and Google says the cradle is "coming soon".. and has for a while now. (https://play.google.com/store/devices/de...)
In short, Gear Live owners are stuck with a charger that easily breaks and can't be readily replaced. Boo.
这个答案有帮助吗?
得分 0
添加一条评论
The easiest way to get around this that I have found with my own broken gear s charger is that you can use a pill bottle. Simply close your watch strap in the locked position place the charger in position, and use a pill bottle to keep enough pressure on it to charge. Make sure the bottle is not too large so that you don't over stretch your band. I did this because I was leary about buying another charger, knowing that the new one would probably break as well in time.
这个答案有帮助吗?
得分 0
添加一条评论
You can get replacement charging cradle easily on Ebay and it works fine.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Keith Cooper 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 3,673
