跳转到主内容
Model A1297 / 2.66, 2.8, 2.93, or 3.06 GHz Core 2 Duo processor
What is the largest SSD available for my MacBook Pro?
The computer is a 3.06 GHz (Mid 2009) MacBook Pro Unibody 17 Inch.
I would like to upgrade my Mac's hard drive to an SSD (Not SSDD hybrid drives). What is the largest hard drive size available for my MacBook Pro?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Here's the details of your system: MacBook Pro 17" 3.06 GHz (Core 2 Duo) Mid-2009. Note the HD's SATA port info.
完成的
添加一条评论
1个答案
已选择的解决方案
As long as it fits within the space (2.5" x 9.5mm) and has the correct SATA interface for your system SATA II (3.0 Gb/s) any SSD should work (that can run at SATA II).
The largest I've seen is 2TB but that will set you back around $3,400. You may want to reconsider the size to something more economical like a 128GB or 256GB unit for around $140~300.
这个答案有帮助吗?
得分 2
6条评论:
Could you put a link for the 2 TB hard drive?
完成的
Here's one: 2TB SSD
完成的
Dan I believe Sata 3 is 6Gb/s.
完成的
Yep, I just checked. It is 6 Gb/s.
完成的
Opps my bad! This system is SATA II not III
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Lucas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 342
