跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
Why is my screen dim?
Hello
I recently repaired an iPhone 3GS. When I had connected the last of the ribbon cables, i turned the phone on. It worked, but it was extremely dim (practically black). I managed to make it to settings and adjust the brightness, but neither sliding it all the way up or all the way down had any effect. Then, when i disconnected the display and tried to connect it again, nothing was displayed at all! What could this be?
I was replacing both the LCD and the glass.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
It sounds to me like a backlight issue. What were you originally repairing on it?
First, double-check the connectors.
Then, I would replace the Display first. If this does not fix the problem, signs point to the logic board, unfortunately.
这个答案有帮助吗?
得分 3
添加一条评论
it could be a bad lcd chip on the logic board. it happens a lot with liquid damaged phones. if a new lcd does not work then i would believe the chip would need to be replaced. no guarantee. it's extremely difficult to solder something that small, but we're champs at it here.
这个答案有帮助吗?
得分 0
添加一条评论
I think you can check the 6R8 coil,most of the backlight issue was caused by this item
这个答案有帮助吗?
得分 0
添加一条评论
Same issue I got.Only difference is My LCD is still working with only exception of very dim screen. Any fix to this issue? Please let us know if you got it fixed.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
sportsrocks213 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 6,040
