跳转到主内容
2.26 or 2.4 GHz / White plastic unibody enclosure
Keyboard and Trackpad not working
MacBook 13" Unibody (Model A1342) Mid 2010
Hello.
I'm in a bit of a pickle. Recently my Dad has been complaining about sensitivity issues with his trackpad, so I set out to adjust the screw; all was well up to this point. While I was reassembling everything the Flex Cable into the trackpad got yanked out. I reseated the cable on both ends, reassembled the machine and wen to fire it up. When it booted up the trackpad and keyboard were unresponsive. I striped it down again and checked the connections and all was fine. Fired it up again and all it would boot to was a gray screen no apple logo. I borrowed my Mouse and Keyboard from my Hackintosh Build and tried to use it to PRAM reset and boot to recovery..etc but nothing will get past the gray screen. The only way I can get it to boot is by {unplugging the battery-hitting the power button few times-reconnecting the battery} this will get me to the desktop where I can use my USB mouse and keyboard only. None of the cables appear to be damaged. Im stumped!
Be grateful to any help
Thank You.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Go over your connectors again. The ribbon cable can be particularly hard to reconnect. If you do not get it back far enough into the connector you could see the sort of issue you're describing.
Yanking out the cable without unlocking it could have damaged the connector or the ribbon or both. (How a ribbon cable connector works)
If this answer is acceptable please remember to return and mark it accepted.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Mike 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 756
