跳转到主内容
Small black headlamp made from waterproof materials with an elastic headband.
Why is my headlamp not turning on?
My headlamp won't turn on! How do I resolve this issue?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
The headlamp fails to turn on after rotating the lens piece to the on position. If this is the problem, either the batteries may be drained or defective and will need to be replaced or the 3V incandescent bulb has burned out and will also need to be replaced.
Problem Remains Unresolved
If replacing the batteries and bulb fail to remedy the problem the circuitry of the headlamp may be fried. If this is the case, the headlamp is unsalvageable.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Every time I’ve had this problem it has been solved by removing corrosion from the copper terminals. With a pocket knife, scrape the contacts until they are shiny again, including the contact under the lightbulb. I also bend the contacts out slightly.
这个答案有帮助吗?
得分 1
1条评论:
Marvellous, worked a treat. Thanks!
完成的
添加一条评论
UNWRAP THE BATTERIES… Sealed in a plastic wrapper…
这个答案有帮助吗?
得分 0
添加一条评论
I added some tin foil on the negative pole of the three batteries, a hack I learned researching why my Mac keyboard kept failing to connect. I was about to throw it away and now it works fine.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mike 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 18
过去 30 天: 113
总计 17,781
