跳转到主内容
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
SSD in the Optical Drive slot?
I'm seeing mixed messages on whether I can use two SSDs - one 512GB in the normal HD slot as my boot disc, and one 256 GB in the optical slot using the Unibody Laptop Dual Drive enclosure. (Unibody Laptop Dual Drive)
Some say the SSD in the optical enclosure will work fine, some say it will crash. To be clear, I just plan on using this SSD as storage, so no system level stuff will be loaded to it.
Increase the storage space in your laptop by replacing the optical drive with a second hard drive or SSD.图片
产品
$24.99
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
It depends on what model you have.
The issue here is the SATA port the optical drive is using is not SATA III (6.0 Gb/s) compliant in all models (clock rate appears to be the factor). So you'll need to get a SSD which you can lock down to SATA II (3.0 Gb/s) to be sure it will work.
这个答案有帮助吗?
得分 0
1条评论:
As reference review the red section at the bottom: OWC Data Doubler. All carriers are effected.
完成的
添加一条评论
I have used Samsung 840 and 840 EVO drives in various models between mid-2010 and late-2012 (non-retina) without any issues in the optical bay.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Don 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 113
