跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
问题已关闭
SSD drives do not work in Yosemite?
I have just received my SSD drive kit to convert my Macbook Pro. I cloned the drive to the SSD but before I commit to it as my boot drive, I read this article that explains non-Apple SSD drives will NOT work in Yosemite. Is this true?
Here is the article:
http://www.larryjordan.biz/caution-ssd-d...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Yes & No ...
The issue is not the SSD device it's self but the TRIM services people add afterwards which is a hardware device driver. If you don't install any 3rd party TRIM service you won't have a issue booting up. But... You will have no means to clean up the SSD when you throw files away (unless the SSD has it's own cleanup service built-in).
The rub here is Apple is tightening down the OS even more (which is a good thing!), but device drivers which are not signed won't load which is where the issue is here. OK, is there a way around this? Yes, but it turns off the the security service across all device drivers (not a good idea). For now you'll need to wait while the TRIM device driver is approved by Apple.
这个答案有帮助吗?
得分 0
添加一条评论
Important to note that you CAN disable KEXT-signing to enable third-party SSD TRIM. While this is undesirable and an additional security risk, it is no less secure than previous versions of the OS that didn't enforce the feature.
I wouldn't hold my breath waiting for Apple to support your third-party SSD. They are going to use this "security feature" to extract additional licensing and control over the hardware. The current Apple direction seems to be to "appliance-iffy" everything and kill the third-party accessory market even in the Macintosh space.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 650
