跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
How to fix my iPhone 5s screen glitches?
Hello, recently I just dropped my iPhone 5s on the ground and the screen has developed these glitches. The touch screen and the touch id works just fine. There are no dead spots. Around two months ago I shattered the screen and I took it to a phone store that fixed it for me. So the screen isn't original, therefore they could have possibly not reassembled it correctly. Just wondering if anybody knows what could possible be the problem? So that if i purchase the tools to open up the phone myself that I could know what to look for and fix. Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 34
8条评论
My Ilhone 5C looks like this except a bit worse and more colourful with the glitch looking lines on the screen. I can't tap anywhere on the screen, it just won't work. I dropped my phone not too long already and it was randomly glitching out weirdly like; the screen would do stuff when I wasn't touching it, screen blackout. And now my phone has just completely stopped all together, I can still press the home and on/off button and I am still receiving notifications. But I'm just wondering if I am able to get the tools and fix it myself? Or if I have to send it in? Or if I have to get a new phone all together!? Plz if u have a solution or any ideas then let me know!
完成的
Same issue. What you have there is a bad LCD. Fixing it yourself would definitely be the cheapest way around it. All the guides and tools you need are here at iFixit, so I would recommend going that route if you are confident enough to do so.
Here is a link to a guide and parts/tools needed to do the repair:
iPhone 5c 前置面板更换
完成的
I have the same issue yet, my phone is completely shattered, front camera will not work, and it's glitched. So, i haven't used it in a while and me and my family are broke to help repair or even buy me a new one. My mom wants to ask some places where they'll help repair or not, but my mom doesn't want to spend so much. Is their any tools i can use to repair or something?
完成的
I have the same issue !! My phone has fallen on the floor and cracked but just a little cracked, after a while it started to have these glitch lines on it so I was wondering what I can do about it?
完成的
I need help my phone will power off automatically and lines will appear on the screens and it glitches what can I do
完成的
显示更多的3条评论
添加一条评论
4个答案
已选择的解决方案
That is simply a bad LCD. It is usually caused by damaging the LCD flex. You are probably going to have to get a new LCD.
Take it back to the store you had it repaired at, if they have a warranty this should cover it.
这个答案有帮助吗?
得分 2
1条评论:
Thank you! So when I took my iPhone 5s to them to have them replace the cracked screen, did they also replace the LCD in the process?
完成的
添加一条评论
Use the lock button to turn the screen off and on again.
Hold down the Sleep/Wake and Home buttons until you see the Apple logo appear to reset your iPhone.
Factory reset and restore your device as a new phone, or restore it from a backup.
这个答案有帮助吗?
得分 1
2条评论:
This didn’t work for me
完成的
Sorry, this was meant for this solution, first time posting :)This fixed my back camera malfunction. Thanks!!
完成的
添加一条评论
I second grimloe this is a busted lcd
这个答案有帮助吗?
得分 0
3条评论:
Thank you for the help!
完成的
did this work? i have the same problem but it's gotten to the point where my phone doesn't work at all
完成的
I have the same problem my friend used my phone and broke my home button and now my screen is glitching and won't even work
完成的
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Graham 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 27
总计 65,330
