跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
Why wont my camera switch to the front one?
When i try to switch cameras, the screen just freezes on the image that was shown before the swap. I realy dont know how to fix it so please help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
First, I recommend resetting your iPod Touch.
If that doesn’t help, I recommend restoring your iPod to factory settings using iTunes. Please make sure you have a backup before restoring your device.
If restoring your iPod Touch does not help, it may be indicative of a hardware problem. If you narrow it down to being a hardware issue, hopefully it is only a loose camera cable. Use this guide to get to the front facing camera. If checking the connection doesn’t resolve the issue, you may need to replace the Front Facing Camera.
Replace a broken or damaged VGA front facing camera compatible with a 4th Generation iPod touch.图片
产品
iPod touch (4th Gen) Front Camera
$14.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Bernado 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 714
