跳转到主内容
關於自行維修iPhone所需的任何一切,從最新的iPhone15產品線,一路追溯到2007年所發布的初代iPhone。iFixit有著每一台iPhone維修指南、拆解資訊,並且完全免費,還有全宇宙最好的更換配件、工具、技巧!
36478 个问题 查看全部
Glass only repairs - Queries...
Im trying to maximize profit on my local repair business so im looking at recycling my own lcd's and reusing them. I have purchased a lcd separator and its great but I have a few queries for someone with a bit more experience on these repairs:
  • Is there a way to remove loca without getting scratches on the lcd? I use the wire trick then remove and left over peices of shards with a playing card.
  • Are scratches noticeable after when i reapply the loca?
  • Whats the optimal plate temperature to use and any suggestions on the thickness of the wire?
  • Any other general tricks or tips? I ended up breaking the first 3 lcd's but after that ive been successful with the next dozen, its the scratches that are stumbling block now.
Any advice would be greatly appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
What machine did you buy?
完成的
添加一条评论
1个答案
There’s a lot to it.
  1. Start up cost - It will cost $2-$4K to get the equipment to properly refurbish. For small time repair shops they have to consider the ROI. Overall I would say you can recover 50-75% of the screens that are good canidates before attempting and the other % is going to break/fallout/defect by the time you’re done or shortly after consumer so the total cost savings will be ~30%. So even in order to break even, you’ll need to run through around 1,000 good screens before you get your initial $ back on the equipment.
  2. Owner Time - Typically, it’s going to be an owner or partner in a cell phone repair shop that attempts to learn how to refurbish at first. You must calculate the cost of your time spent (because it will take many hundreds of hours) to get it all down. Is this time the best spent away from your core business? Maybe, maybe not.
  3. Employees - After the owner has learned how to do it they will usually hand it off to one of their lead techs to help out. Typical cell phone repair employees do well but not enough that they often get the itch to go do their own refurbishing for others…and why not? They can get 3-4 local repair shops in their area and make 2-3X as much money as being a repair tech working less hours and on their own time. This sort of goes hand in hand with #2 because the longevity of a solid LCD repair program means a top level person is going to need to head it. Do you have this person?
  4. Economies of scale - This is a double edged sword. It’s easy to get 1 refurbished or a handful. But to get hundreds done a month means you need a supply chain of repair parts always on hand and the cash to do so. It means you have a lot more numbers to record to ensure you’re profiting …meaning, parts consumption, failure records etc. The more screens you have to refurbish the lower the cost SHOULD go, IF you’re able to keep up with tracking the volume.
  5. Market Awareness - Sometimes, it’s just not worth refurbishing due to the cost you can get from recycling the screens through a buyback company . You need to be intune with market prices because sometimes it makes better sense to just recycle for cash and not spend time, money, parts on something that has an alternative choice that yields the same, close or better $.
Bottom line I would say it make sure you have a solid way of tracking the costs of repairs (yields, parts consumption & labor) so you’ll actually know if it’s all worth it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Wes 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 118
