跳转到主内容
加入维修社区 - 创建账户
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
Only background showing and not working, not closing?
I have IOS 8. I was reading a pdf on Adobe last night, my charge was gone so it closed. Then I recharged it. I tried opening it. The background appears. no pass word, screen lock. no apps. no up or down manues. nothing. I tried switchin it, does not switch. I pressed the up and down bottons at the same time. apple logo appears, the screen goes blank, after a while, the same background appears. my own background. Ive tried this many times
回答此问题 我也有这个问题
这是一个好问题吗?
得分 9
17条评论
there is also a stage where ipad opens with clock and date showing as it is supposed to, but the screen is extra extra large and does not reduce. I can open the drop down menu above, still extra large.
完成的
I tapped the screen with three finger twice, and it opened.
完成的
I have the same issue and nothing is working not even rebooting it works :(
完成的
same thing hapened to me, what I did is press and hold the power button and home button
完成的
Danika, THANK YOU SO MUCH
完成的
显示更多的12条评论
添加一条评论
11个答案
最有帮助的答案
Try pressing home button and power button for like 10 seconds should either power off or reboot if powers off turn back on see if fixes if not plug into computer and see if sees it if does may need to reload os if not might be S.O.L.
这个答案有帮助吗?
得分 13
12条评论:
thank you. pressing buttnons like that do not help.
完成的
Thank you it worked I was so worried
完成的
thank you so much !! life saver
完成的
it worked!! yippeee!! thank you so much
完成的
thank you so much
完成的
显示更多的7条评论
添加一条评论
I just switched off my phone, then i held the home button and the power button at the exact same time for like 5 seconds then you see a blue screen then it turns black and you will see the apple logo and if it starts its all fine
这个答案有帮助吗?
得分 3
1条评论:
Thank you! My phone is saved :)
完成的
添加一条评论
Are you able to power the unit off? If so, plug it in, turn it off and leave it sit overnight. At least 8 hours. Sometimes they come back from weird errors like after a timeout and a good charge.
If that doesn't work (don't be surprised if it doesn't), then its time for a restore. Plug the iPad into your computer, hold down the power button for 5 seconds. Then press and hold the home button for 15 seconds while still holding power. Then the "connect to iTunes" should appear. In iTunes, select restore, and let the device wipe and install.
If that doesn't work, please update. Its possible that it could be hardware but I'd bet on a software glitch.
这个答案有帮助吗?
得分 1
添加一条评论
I have the same problem. Updated yesterday and it kept freezing up so I shut it down and it loaded with the apple Icon by then only the clock shows. It won't shut down again. Basically the upgrade screwed up my Ipad. Nice going Apple. :-(
这个答案有帮助吗?
得分 0
添加一条评论
hold power and home button at the same time for ten seconds
这个答案有帮助吗?
得分 0
添加一条评论
The same thing happened to me
But what can I do to fix it when my home button doesnt work???
这个答案有帮助吗?
得分 0
1条评论:
I have the same problem too? Anyone can help?
完成的
添加一条评论
Can i get help my friend's iphone not working she cant do enithing. Thanks
这个答案有帮助吗?
得分 0
添加一条评论
try placing it in some fire. when it burns for about 10-15 minutes then out the fire with some honey and try powering it on with a block of cheese. If that doesn't work power it on with a hammer for 8 seconds then toss if off a cliff, by then it should start working.. working well out of you life, so you can then go purchase a better &&^&^$^ device you stupid @%^$$@$!!
这个答案有帮助吗?
得分 0
1条评论:
Wtf? (What the flip)
完成的
添加一条评论
Hi I learned that if you put ur phone/I pad in the microwave for 5-10 min it will solve that problem thank you for every one who told me that.
这个答案有帮助吗?
得分 0
1条评论:
And then eat it. That should work.
完成的
添加一条评论
I don't have an answer but I have a question. I have a Zte Whirl that still works but stays on a black screen. Can you help me solve this problem please?
这个答案有帮助吗?
得分 0
添加一条评论
my phone isn't displaying words just the background. what should I do?
这个答案有帮助吗?
得分 0
1条评论:
This is not an answer :P
完成的
添加一条评论
添加你的答案
nur 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 28
总计 37,705
