跳转到主内容
The Moto G is Motorola's economically priced phone. It has all the features one could want in a smart phone, for half the price. Model numbers XT1032, XT1033, and XT1036.
86 个问题 查看全部
Why am I not getting sound from headphones when plugged in phone?
When I plug my headphones into my Motorola Moto G headphone audio jack, no sound is coming out of the headphone speakers. What could be the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I was watching a video on my laptop and it was working fine and after that there was no sound please help
完成的
添加一条评论
3个答案
最有帮助的答案
First check and see if your phone is under warranty. If not under warranty check the volume settings. If volume is set correctly try turning phone completely off to reset. Next try replacing the headphones or accessory you have plugged into the jack. If there is still no resolution the jack may need to be replaced.
这个答案有帮助吗?
得分 1
添加一条评论
put phone into safe mode then delete all apps then restart phone then if it doesnt work do it again but delete all apps that you have recently downloaded
这个答案有帮助吗?
得分 0
添加一条评论
or dip jack tip in slight water dry a little insert again make sure your not drowning the piece your just trying to restore the conductivity of the jack itself
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Matthew Byram 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 11
总计 9,134
