跳转到主内容
Bootable flash drive for Windows Bootcamp install won't work
Hi, I have a MacBook Pro from 2010-2011 (when I bought it brand new it was running 10.6.8).
I just barely did a clean install of Yosemite. I did a clean install because I wanted to defrag my HD so I could create a windows partition in boot camp (before the clean install, it would only let me partition 33 GB no matter how many files I deleted).
Anyway, now I can make the windows partition as large as I want it. But now here's the problem. I have a broken disc drive due to a physical accident a while back. So I want to use a USB flash drive to install windows with boot camp. I created a bootable flash drive of windows that I downloaded from Microsoft.
My computer successfully creates the partition, but when it restarts to install Windows, it does not recognize the bootable flash drive. The black screen says "no bootable disk, press any key to reboot."
Note: I'm using the exact same flash drive I used to install Yosemite. It worked great. It is a 15 GB 2.0. Also, I created the bootable drive using boot camp (I used the terminal and bootcamp's .plist to allow Yosemite's boot camp the "create bootable USB drive" option.
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
The problem you are facing here is the way the flash drive is setup. You'll need a second one to setup Windows from a windows system. If your optical drive was working it would be much easier to install as the Windows disk would be bootable under Windows.
The issue is the lower level structure OS-X uses is different than what MS Windows uses.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Phil 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,964
