跳转到主内容
这一代一体成型铝机身的Mac mini型号为A1347,包括2010年中期至现在在售的2014晚期型号。
872 个问题 查看全部
Remove Harddrive (Standard macmini 2010)
Do i have to remove the logicboard to remove the harddrive?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
4个答案
最有帮助的答案
Looking at step 12 (page) of the tear down, the 2nd picture, with the color coded squares, you can see tabs/guides on the harddrive bracket that kept it secured in place.
Then, from step 14 (page 2) it looks like the RAM sockets are in the way, so it does appear that you do have to pull the logic board out, at least partially, if not completely.
Mac Mini Mid 2010 Teardown
这个答案有帮助吗?
得分 1
添加一条评论
I took it out without removing the logic board. But I would not recommend it. You will at least scratch the black protective plastic that is around it if you do.
这个答案有帮助吗?
得分 1
添加一条评论
See this previous Answer.
这个答案有帮助吗?
得分 0
添加一条评论
I did get it out without pulling the logic board. It was a bit tight, but doable. I would not go so far as to not recommend it, but it would be easier if the logic board is at least partially out. It was a tight squeeze.
I did remove the RAM, the fan and the wireless antenna.
I did it this way because I was not able to make my "magic tool" work. Try as I might, the logic board did not move. Need more details on what is supposed to happen with the magic tool.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mike 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 15,097
