跳转到主内容
加入维修社区 - 创建账户
型号A1367,闪存容量:8、16、32及64GB
Screen Doesn't Stay Down After Replacement
I tried setting a stack of books on the iPod and other things like that, but the adhesive you provided me in my order doesn't appear to be keeping the screen down. Is there a tool that will "clamp down" on the iPod to hopefully get it in position long enough that the adhesive eventually holds it down?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
There are a bunch of threads on here that are very detailed describing everyone's tips and tricks with the touch 4 screen lifting. It is a difficult problem that boils down to needing the frame to be 100% square and everything 100% perfect inside. If the screen doesn't snap in firmly w/o adhesive, then it will always have a lift. You have to edit the assembly, possibly replacing the whole frame, until you get that perfect fit. The adhesive is just a small crutch. Never use glue or epoxy in a phone--IMO
jessa
这个答案有帮助吗?
得分 1
添加一条评论
are you sure theres nothing underneath pushing it up, what adhesive did they provide?
这个答案有帮助吗?
得分 0
3条评论:
It's all good underneath. They provided me the adhesive strips that are on a sheet. You just peel them off the sheet and apply them to where they go on the iPod. Then, you peel off the protective layer on the adhesive and just lay the screen over all the adhesive areas you just applied.
完成的
personally mate, im not a fan of them strips, i know exactly what you are talking about, i prefer using different type of adhesive for an ipod, because its got no screws to help hold it down, you need something strong, try using a stronger glue/tape
完成的
Yup had same issue on iPod i was fixing for a friend ended up using epoxy
完成的
添加一条评论
Thanks you two! I appreciate the input. I'll look into the epoxy. Take care!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
janesglfr 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 232
