跳转到主内容
加入维修社区 - 创建账户
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
iPhone 4s bootloop after screen replacement
Just changed the screen and the iphone now is in bootloop with the apple logo. The logic board apparently has no problem (I checked with macro lens). I tested the lcd in another Iphone and it perfect work. This is a video with the problem https://www.youtube.com/watch?v=p-dz2SDV...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
5个答案
最有帮助的答案
Hi.. I tried a new battery, that's what caused the boot loop (3600mah)..
I fixed this on this phone.. Maybe entirely different cause for some one else..
I noticed a power drain last night after swapping the gutt's to a new shell.. Everything worked fine, so presumed the battery was shot.. So changed it for a high powered battery, which seemed to work fine.. Was about to call the client to say its fixed, one last test.. Boot loop!!
Any way.. After searching lots of posts like this one decided to check for shorts.. Took every thing back out, tested the board while it was unscrewed, but still in place.. It worked!
So screwed it back together testing the boot sequence with every few screws.. The very last connector.. Front facing camera flex! Boot loop.. If I unplug it while in boot loop it works fine and boots up.. So I'm just waiting for a replacement flex and preying the fault is the flex and not on the logic board.. Fingers crossed
这个答案有帮助吗?
得分 1
添加一条评论
Surely you know that there isn't such a thing as a high powered battery for a iPhone!
The that so called high power battery would probably cause more damage than good.
I would just swap it out for a good proper battery and take no chances
这个答案有帮助吗?
得分 1
添加一条评论
Is There anyone who can help me?
这个答案有帮助吗?
得分 0
添加一条评论
Apparently Not... I have the same problem - iphone 5 :(
这个答案有帮助吗?
得分 0
添加一条评论
Hello have you tried a new battery that would be the first thing til do
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Marco Micheli 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 873
