My tablet is not charging, can anyone help?
My tablet was running low on power today so I decided to charge it at school. But, when I took my charger out of my bag and plugged it in I didn't see the charging icon. Is my tablet broken?
Your tablet may not be broken. It's important to determine first that is not the charger or the wall outlet you were using. Try charging it somewhere else out using a different cord. If neither of those solutions work then your tablet's battery night be dead. There is a replacement guide for that here on ifixit if you need it.
这个答案有帮助吗?
My tablet charging but not start only just blink
Your tab was not charging and not see the charging icon in the tab you will do that first power off your tablet and connect to the charger if there are not show in the tab the battery is not charging then press the power off button and volume button press the both buttons together quickly and this show the many type of option you will select the option factory reset and backup using your up volume key to highlight and press down volume to select the option and then select yes your tab was booting and this may show the charging icon and the tab battery was charging. After this process cannot be work repair your charging point in the tab to mobiles repairs shop.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 3,485
