跳转到主内容
加入维修社区 - 创建账户
The Blackberry Torch 9810 is an updated version of the 9800 Blackberry. Released in 2011 and has since been discontinued.
Why won't my phone turn on?
I put my phone to charge last night and when I woke up it was off. I tried taking out the battery, but that was useless. What do I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
2条评论:
me too I have the same problem, when I change my Sim Card yasterday, my phone did not open up to now
完成的
hi pls I need help with my blackberry torch 9810 which I got from someone. The next day I got a new battery for the phone and when I put it in it started blinking the red light and didn't stop I tried leaving the phone to charge but no solution even while the charger is plugged it blinks red light. I brushed the logic board with a solution and dried it. I was in the middle of trying to leave to phone to charge for 2 hours and then pull out the battery for 15 minutes before putting it again for another 2 hours. pls can someone help me pls I would be really grateful, thank u
完成的
添加一条评论
3个答案
First check to insure your charger cord is not ruined. Many times this can be the main reason why your phone isn't charging. Try using a friend's cord or an additional one that you may have laying around. If this still doesn't work you will probably have to replace your battery. That is an easy fix! Hopefully that works, but if not your logic board must be replaced.
这个答案有帮助吗?
得分 0
添加一条评论
Heat the panel with paste if it dosnt work change the flex
这个答案有帮助吗?
得分 0
添加一条评论
when i turn on my phone it's say "error 507".what do i do ?
这个答案有帮助吗?
得分 0
1条评论:
Open blackberry device manager on PC, connect blackberry device using USB cable without battery and continue repair option on PC with blackberry device manager.
完成的
添加一条评论
添加你的答案
Jocelyn Adorno 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 14
总计 3,275
