跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
Can the digitizer tearing cause itunes to not detect iPhone
My iphone 5c fell and the screen literally separated from the back of the device. I tried to put it back on and when I did it didn't turn on, then i tried to connected to iTunes but it could not be detected in other words nothing came up. Then i noticed that a little piece from the back of the screen was broken, I started searching for the name of that piece and found out that is called the "Digitizer" or "LCD" I'm trying to get all of my photos since i never used iCloud nor iTunes backup. So my question are: does the digitizer have anything to do with my phone not turning on? Or is there something else wrong that is causing this? And will all my data be erased? Please help by answering these questions
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
Usually, the digitizer will not prevent the phone being recognized by iTunes. If you can not see any type of picture on the screen, then it could be the LCD broke. A simple screen replacement should help and fix the screen and LCD issue. As far as iTunes, try a hard reset and see if that helps.
这个答案有帮助吗?
得分 0
3条评论:
Also, replacing the screen should not corrupt your data that is on the phone
完成的
So I just need to buy an LCD, because the screen didn't cracked or anything, It just came off.
完成的
Also you mentioned that I need to try a hard reset will that erase my data?
完成的
添加一条评论
If iTunes isnt reconising it then there's no power getting to the iPhone
The drop could have also damaged the battery
这个答案有帮助吗?
得分 0
1条评论:
And once replacing the battery it won't affect my data in it?
完成的
添加一条评论
添加你的答案
Ida Mendoza 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 91
