跳转到主内容
The UP! Plus 2 is a 3D printer manufactured by PP3DP for home or professional use and is capable of printing objects of up to 140W x 140D x 135H (mm).
Why isn't my printer turning on?
The front facing power light is not turning on, even when my printer is plugged in and the switch is on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
This could be an issue with your power supply, or it could be the motherboard. Once the supply is plugged in check to see if the blue light is on on your power supply. If the light does not light up please refer to the power supply replacement guide.
这个答案有帮助吗?
得分 1
添加一条评论
Make sure you have the power flipped to the right voltage for your area.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
valerie boyer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 529
