跳转到主内容
The UP! Plus 2 is a 3D printer manufactured by PP3DP for home or professional use and is capable of printing objects of up to 140W x 140D x 135H (mm).
Printer that is not initializing correctly and skipping?
I've had my printer for a while now, and I've run into an issue where my printer will start skipping and pushing it's y-limit boundary. There is no "click" of the switch in the back.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
If your printer is going too far back and there is no audible click then your y-limit is malfunctioning. This means your mechanical limit switch is either not connected or malfunctioned and should be replaced.
这个答案有帮助吗?
得分 1
添加一条评论
make sure the firmware is updated and check the bed range settings in your slicing software.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Spencer Jefferson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 449
