跳转到主内容
加入维修社区 - 创建账户
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
SMC reset without power button
I watered my MBA a few weeks ago and it stopped working. After a proper cleaning procedure and replacement of the keyboard, it started working again but a few problems have arisen:
1) fans moving very fast and not quitting at all
2) power button not working
3) when fans are on, the MBA is very slow
I would like to reset the SMC in order to understand if I can reboot the system somehow; however, the procedure includes the pressure of the power button.
Is there any possibility to reset the SMC without that button as it doesn't work?
Thank you in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
It is possible to jump start the machine. You will have to disconnect the keyboard and short pins.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 1
1条评论:
what does a jump-start cause? is it a total reboot or just a swich on of the machine? I read the link page and it seems just a boot of the MBA. I already disconnected the battery and the machine turns on every time I plug the power adapter.
完成的
添加一条评论
It is not a total reboot, it just turns on the machine. That said, unplugging the battery and the power for a bit (30 mins?) should accomplish an SMC reset.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
madmagazine 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 2,431
