跳转到主内容
上网本也时常需要维修,所以要随身携带我们的指南。
Screen replacement for Nextbook 8 NX785QC8G
I recently dropped my Nextbook 8 and the Digitizer broke, I need to replace it but I don't know how to take it apart since it has no screws on the outside. I also need a link to a new digitizer screen because I'm not sure as to which one it needs. Thank you for your help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 14
1条评论
Where can I buy a screen for it
完成的
添加一条评论
5个答案
最有帮助的答案
You could buy a new digitizer from ebay
New-Digitizer-Touch-Screen-Panel-For-Nex...
这个答案有帮助吗?
得分 3
添加一条评论
if you look at the edge of the tablet there's a seam. you want to get a really tiny screwdriver and slow try to open it. when you hear a pop that means the clips on the inside have released and you want to do that all the way around the side of the tablet.
By,Jahn Peabody
这个答案有帮助吗?
得分 2
1条评论:
After I put it back together the touch screen is not working and it w
as before. No I have not replaced the screen as of yet.
完成的
添加一条评论
I think I'm having the same problem. Dropped my nextbook and it is cracked across the screen. It's crack left to right at the middle of the tablet. I can't use the top portion because the touch screen isn't working on the top. Bellow the crack it's fine. How would I go about replacing it when I get the screen replacement?
这个答案有帮助吗?
得分 1
添加一条评论
Yes how much it cost to replace it
这个答案有帮助吗?
得分 0
添加一条评论
How to fix the part were the charger goes into the nextbook
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alexander 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 5,794
