跳转到主内容
任天堂 3DS 的升级版。它拥有更大的屏幕、更长的电池续航时间、更高的像素密度和更好的设计。
My upper LCD screen doesn't have backlight
Hi, this problem appeared yesterday. I was playing some Smash Bros. and suddenly my upper screen went black. 1 minute after that it shut down with a popping sound.
The screen is still working, I can see images if I lit it up with a flashlight, so it's just my backlight that doesn't work.
I reconnected ALL the connections inside my 3DS XL and rebooted it, but the same problem was still there.
Should I buy an entire new LCD for this or am I missing something?
Thanks for everything.
EDIT: I replaced the LCD screen for a new one and the console still has the EXACT SAME PROBLEM. I really have no idea of what could it be now.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论:
Have you replaced the speaker ribbon cable? If you take off the back of the top case you will be able to see where the speaker ribbon cable goes through the metal tube. Many times there is a small tear in this cable that causes this problem.
完成的
添加一条评论
2个答案
I'd recommend a new LCD, since the Backlight is integrated into it and it is nearly impossible to fix a display.
这个答案有帮助吗?
得分 0
添加一条评论
Did you manage to solve this problem? I'm in the same situation.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gorrin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 485
