跳转到主内容
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 个问题 查看全部
Wifi and Ethernet Connectivity Issues
Hi everyone,
I have a 2008 Macbook Pro (2.4 GHz, 4 GB RAM, 500 GB HD) running on the newest version of Mavericks software. I have had numerous problems with this Mac (the latest required a new logic board and hard drive) but the latest is that it intermittently drops the wifi or ethernet connection that it is on at a given time. It will be working fine and then seems to randomly drop the connection. I have tried running permissions repair, disk repair, ONYX, removing and re configuring both my wifi and ethernet connections, doing a clean re-install of mavericks (without using time machine), SMC reset, PRAM reset, running a software update, and both quick and long hardware tests (tested normal both times). Apple refuses to see the product (despite them doing all the previous repairs on it earlier this year) because now it is considered a "vintage" product.
The only thing I have found that makes the internet connection work again is to restart the computer. Turning the wifi off and then back on does nothing. Any ideas?
*Update: I was just told by a repair guy that it is the Left I/O Board. Anyone concur? Anyone disagree?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
What OS are you using? Mavericks has a lot of network drop/ wake from sleep issues
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 1
3条评论:
I am on Mavericks. I guess that would be an easy and cheaper fix to just roll back to Mountain Lion if that's possible rather than swapping out the left I/O board. Too bad I've already opened it up and started taking things out...
完成的
I just rolled back to Snow Leopard and guess what? I am having no issues so far! Thanks machead3 for your suggestion!
完成的
Yea on a box that age Mavericks and Yosemite are really pushing it. Unless you had a new peripheral that demanded either of those OS's I'd stick with 10.7.x maybe 10.8.x as the highest OS upgrade.
完成的
添加一条评论
添加你的答案
Kyle 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 665
