跳转到主内容
加入维修社区 - 创建账户
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
Airport doesn't pick up wifi after hard drive switch.
Hi All,
I used this guide to replace my hard drive (which works great btw), but somehow in the process I messed up my airport card. If the iMac is right next to the router it will pick it up, but move it to the next room and it see's nothing, even though my laptop gets full bars.
This makes me think I unplugged the antenna for it (does it even have one?), but going back through the guide I didn't see it mentioned. Also, I'm not sure if it matters but I was never able to get the front bezel latch to close correctly when I put it all back together.
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
4个答案
最有帮助的答案
The iMac has an internal AirPort Extreme card. Attached to this card is two antennae cables. See the image for Step 10 in the following iFixIt link:
这个答案有帮助吗?
得分 3
添加一条评论
Hi Leon,
It was deja vu all over again reading your problem since until 5 minutes ago I had the exact same issue. I tried opening the iMac back up, checking the airport card connection and even repaired the tears I had made in the shielding with aluminum tape all to no avail. I got it working again by doing something very odd that I read in a post somewhere about I think a MacBook Pro:
Try logging onto your airport with airport utility and take it off the "automatic channel" setting in favor of a specific channel (I happened to choose 6). For reasons I don't understand this fixed the problem for me and I hope it will do so for you, too!
-Bob
这个答案有帮助吗?
得分 1
添加一条评论
I bought a used iMac with the same issue. The previous owner had the hard drive replaced. I replace the card - exact same. So I was still puzzled and did a little experiment. I could never find any documentation on the two different antenna leads so switched the two antenna cables - PRESTO - works great.
这个答案有帮助吗?
得分 1
添加一条评论
I find to have the same issue as described by Leon.
Problem is, I tried to reopen my iMac, but it won't open the front bezel with the card trick..
So I opened it from the bottem and undid the EMI shield. It appears there's only one antenna attached to my airport card.
does anyone know if this is normal, or should it always have two antenna's?
Is there a way to fix this? Maybe by creating my own antenna somehow?
Thanks!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
leon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 2,665
