跳转到主内容
4英寸屏幕;多种颜色可选;共发布三款型号;闪存容量:16、32及64GB
331 个问题 查看全部
iPod will not turn on?
I was using the iPod Touch (16GB, no camera) when it suddenly turned off and would not turn back on. Tried charging it for several hours and no change, it still won't turn on. Could it be the battery needs replacing? Seems the logical place to start but wasn't sure?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
添加一条评论
6个答案
最有帮助的答案
Try the easiest first....try cleaning out the dock connector with some canned air to see if there's anything keeping a good connection from being made. If that doesn't work, open it up and see if anything has come loose/broken etc.
这个答案有帮助吗?
得分 2
添加一条评论
Have you tried plugging it into the computer to see if it registers? If it gives you an error, maybe google the error to see the meaning. Just a thought
这个答案有帮助吗?
得分 1
1条评论:
i have the same problem with mine. t does not register when i plug it into the computer, also the home button did not work prior to this. Help?
完成的
添加一条评论
was there a solution? if so please list what it was. Thank You!
这个答案有帮助吗?
得分 0
添加一条评论
mine dosnt reg wen plug into laptop either
这个答案有帮助吗?
得分 0
添加一条评论
Long time since this was posted, but I had a similar problem. iPod would not turn on, nor take a charge.
I was able to fix it by plugging it into a power source then pressing the home and power button and holding both for about 30 seconds. The Apple logo popped up and it would now take a charge and power on.
这个答案有帮助吗?
得分 0
添加一条评论
How do you restore iPod when it’s locked showing USB to iTunes and says can’t restore, no network
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kelly P 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 14
总计 2,527
