Why am I having difficulties with the Battery life?
After I charge the tablet, the actual Battery life is much shorter than the estimated one.
First, start by checking the Settings on your device. You can also proceed to check for water damage as well. Additionally, you can check the internal wiring of the device. Lastly, if none of the previous steps work, click on the Battery Replacement Guide and follow the steps outlined.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 138
After doing some research, I believe that I have found the answer to my own question.
由 Gabriel Delgado 完成的
